VideoHelp.com Forum
    I need to know, if one VOB file can be 4 GB big. I want join 4 VOB files to one big file with VOB Edit, but I donīt know if it will work for me.
    May be itīs stupid question.
    Hi,
    First off, Yes a vob file can be 4 Gb big. I don't know if VOBedit can create these, but a vob file can be 4 Gb big. DVD-Decrypter can rip to 1 big vob file creating even bigger files than 4 Gb.
    Secondly, Why would you wanna create a 4Gb vob ?!?!?
    Greetz,
    pSyChO dAd
    The difference between genius and insanity is only measured by success !
    I want this big VOB for VirtualDub Mod to make VCD or SVCD with permanent subtitles using TMPGEnc. But Virtual Dub Mod can load only one VOB file, but on my DVD disk I have 3 VOB files. And I hope that this way will by solution of my problem. There is DVDx using TMPGEnc, but I donīt want this soft.
  4. Could please tell me how to join many vob files into a big one? i need to join like 20 vob files which are 4.2 gb into one big file.
    Thanks in advance.
  5. I see a problem, Depending on your OS. XP is the only windows that I know of that can read a file that is 4gig or bigger. I use DVD decrypter and tell it to make one VOB all the time.
  1. Dvd with subtitles and Audio tracks in one big vob file help converting
    By jimbobob84 in forum Newbie / General discussions
    Last Post: 22nd Dec 2009, 02:09
  2. Joined VOB files... but length remains splitted?
    By Metallo in forum Authoring (DVD)
    Last Post: 7th Nov 2009, 03:44
  3. Joined avi file conversion problem
    By siberian50 in forum Mac
    Last Post: 26th May 2007, 19:04
  4. Revised Question: Problem playing joined file on windows media player
    By Johnny_Blaze in forum Newbie / General discussions
    Last Post: 15th May 2007, 12:25
  5. Problem Viewing joined hjsplit .avi file in Windows Media Player
    Last Post: 13th May 2007, 16:22
