VideoHelp.com Forum
  1. Hey!
    Everybody always said that VCD hacks for the LG-5822N was NOT possible until... someone found out how to do it. And it WORKED!!
    Everybody always said that SuperVCD hacks for the LG-5822N was NOT possible until... someone found out how to do it. And it WORKED!!
    I KNOW for a fact, because there were people on pages on the internet that said they HACKED their 5822N for Macrovision (instead of the old microchip change) and it WORKED... only I couldn't find anyone who was kind enough to explain how to do it.
    Any good hearted people out there, please?
    Thanks!
  2. how can i hack my lg 5822n for svcd? I have the vcd hack...but i canīt play svcd...
  3. its the same hack for all LG 5xxx player...
    3 user hacks: Add hack
    Region code hack posted by creepingdemon@home.nl at February 13 2003:
    Taken from the 'LG 5630' post, tested and worked on the LG 5620 PAL! Have phun!
    Region code hack posted by Fitnessman at January 22 2003:
    ENABLE SVCD ON LG DA-5630 home cinema
    (tryed with PAL system, NTSC no info - maybe)
    1, Power on your DVD without disk (display "NO DISK")
    2, Press PAUSE
    3, Press on remote control: 1,4,7,2 (you're in service mode: first write the origin characters)and
    4, Press UP ARROW (^) key 6 times - on display (in the first row) you see the origin 00 characters
    5, Press PROGRAM and 6 keys after press PROGRAM and 5 (the 00 characters changed FE)
    6, Press ENTER and RETURN
    7, Turn power off and power on the DVD player
    It's amazing! Your DVD can play the SVCD!!! )
  4. change the 7th set of numbers from whatever they are to FE.
    press programme,then 6,then press programme then 5.
    then pause and off then on..
    and thats svcd enabled.
    for vcd..its the 4th set you change from whatever to FE.
  5. thanks, it worked with me.
    This hack looks like the Zenith XBV model Hack! Must be the same unit.
  1. Macrovision like NONE OTHER
    By blacksheepdownunder in forum Capturing
    Last Post: 22nd Jul 2010, 04:16
  2. Macrovision and MPEG?
    By plugues in forum Newbie / General discussions
    Last Post: 22nd Oct 2009, 20:01
  3. Is it Old or is it Macrovision?
    By Tiggerpaws in forum Restoration
    Last Post: 7th Aug 2009, 16:31
  4. Macrovision
    By adamrose in forum Newbie / General discussions
    Last Post: 22nd May 2008, 20:41
  5. Macrovision Help!
    By dollydoodledumplin in forum DVD & Blu-ray Recorders
    Last Post: 24th Nov 2007, 10:37
