VideoHelp.com Forum
Results 1 to 9 of 9
  1. Hi !
    I"m totally new with capture thing. All i want is capture video from Direct TV and VHS to DVD quality. I found some guide but need more detail seen i'm new ...Like i tired to capture using MMC 7.5 TV and i don't know what to do with the out-put file (*.mp2)???? Please help me out here. Thanks alot guy
    I got ATI AIW 8500DV 64MB DDR.
    =-VNPN=-
  2. Member rhegedus's Avatar
    Your capture will only be as good as the quality you start with, at best.
    This should help:
    http://www.dvdrhelp.com/capture
    Regards,
    Rob
  3. i went there and most of them is the setting with capture... to VCD or SVCD ... not DVD .
    =-VNPN=-
  4. Member rhegedus's Avatar
    I'm not sure if your card can capture to mpeg2 (dvd format) directly, so I suggest capturing to avi (uncompressed) and then convert to mpeg2.
    Your specs don't indicate that you have a dvd burner - are you sure you want to do this?
    Regards,
    Rob
  5. I think ATI AIW 8500DV can to realtime to mpeg2. And i do have dvd burner. When i use ATI MMC 7.5 capture the movie from direct tv, it come out with file name *mp2 ....... and i really don't know what to do with that file........ Most of the guide that show the setting not step by step with the file. THanks for your help.
    =-VNPN=-
    I think VirtualVCR is the best (free) AVI capture tool. Give it a try. I'm sure u won't be disappointed.
    http://www.digtv.ws/
    If u wanna do mpeg2 captures in realtime, then PowerVCR is gr8. ShowShifter works like a charm for realtime DivX capture.
    - Keith
    Well, seems that you are worried about mp2 name...
    it is just the name MMC gives to MPEG-2 files... if you are not glad with mp2 extension, rename it to mpg...
    but MMC files are not compliant files, as I know... you will need some tweaks... find in tools section MMC REGTOOL and give a try...
    Fredİ
  8. Thanks alot for all your help guys.
    =-VNPN=-
  9. Member rhegedus's Avatar
    Can you update your PC specs - to save us groping around in the dark next time?
    Regards,
    Rob
  1. Sony DV Direct VHS to DVD Conversion Problem with Model VRD-MC6
    By WRArtMonk in forum Newbie / General discussions
    Last Post: 21st Nov 2011, 04:02
  2. SONY DV Direct VHS to DVD Conversion Issue with VRD-MC6
    By WRArtMonk in forum Video Conversion
    Last Post: 6th Jan 2011, 08:51
  3. newbie question, vhs tracks
    By alcez in forum Audio
    Last Post: 16th Oct 2009, 11:41
  4. Replies: 3
    Last Post: 16th Sep 2009, 09:09
  5. Replies: 27
    Last Post: 4th May 2009, 13:57
