I have a movie that plays fine in Windows Media player but when I open it up in Virtual Dub and scan for error it finds 1 bad frame and 38 good but undecodable. How can Media Player play this without any problems but Virtual Dub is telling me there are errors. Seeing as I can play it in Media player I've tried to screen capture frame by frame for that small section that Virtual dub says has erros but when I paste it in Adobe photoshop it is behaving rather strangley. If I capture the whole screen and then try to crop it down the movie frame moves (I can't figure it out. It even does this when I use Snagit) I don't really care if I have to delete that 1 frame but I'm having a hard time understanding why Media Player can play it without problems.
Any suggestions? Do I keep trying to capture frame by frame like what I've been doing but with another program? I've also tried to capture video using Snagit but it is really slow. The sound will be at normal speed but the frame rate is really lagging. I've got a decent computer and memory (AMD 1800 with 64 mb ram Video Card and 1GB of DDR RAM). All I need it to capture a few seconds of video. Any suggestions would be greatly appreciated, Thanks
Thread: Fixing Bad frames
After scanning for bad frames set both audio and video to direct stream copy then save avi. The bad and undecodable frames will be removed in the resulting saved file.
Playing programs will skip over the bad frames but encoders will choke on them giving all kinds of problems."Art is making something out of nothing and selling it." - Frank Zappa
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
Fixing [D] Frames?
By Startropic1 in forum Video ConversionReplies: 1Last Post: 9th May 2010, 11:03 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
Problem Fixing corrupted frames
By Blå_Mocka in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2007, 08:44 -
Fixing bad tracking
By J C in forum RestorationReplies: 11Last Post: 7th Sep 2007, 07:11
Statistics
Newest guides
Latest tool updates
New media comments
