VideoHelp.com Forum
  1. hi to all,i have a problem with ffmpegX 0.0.6m i have an uncompressed .mov file i got from my video redigering software i wanna make a SVCD of that movie using ffmpegX but each time i get this error message in the terminal
    Encoding started on Tue May 20 22:00:05 CEST 2003
    2003-05-20 22:00:05.484 movtoy4m[831] *** Uncaught exception: <NSInvalidArgumentException> *** -[NSURL initFileURLWithPath:]: must supply a non=empty path
    i have a ti800,the movie file is 44gb in my external firewire hard drive and i use mac os 10.2.5.thks a lot for any input.
  2. Could you please copy and paste what you have in your "Open..." field before hitting the "Encode" button.
  3. thks for ur answer,i'll do that tonight cauz i am not home now.
  4. the path was like that : /Volumes/Scratch/Séquence 1.mov
    and then i remembered about spaces and stuff so i tried with that path(changing the name of the source file) : /Volumes/Scratch/Séquence1.mov
    but no luck the message error is this one(i think still the same) :
    Last login: Wed May 21 18:34:21 on ttyp1
    pbpaste | sh
    Welcome to Darwin!
    [la-bouass-Computer:~] labouas% pbpaste | sh
    Encoding started on Wed May 21 18:34:22 CEST 2003
    2003-05-21 18:34:22.297 movtoy4m[1123] *** Uncaught exception: <NSInvalidArgumentException> *** -[NSURL initFileURLWithPath:]: must supply a non=empty path
    hope that helps,could it be the little accent on the "é"??
    thks for any help.
  5. Originally Posted by labouas
    thks for any help.
    It could be the accent. Try removing it.
  6. it worked!! htks for ur help major.btw i film with a sony dcr pc8 miniDV PAL,then edit and burn a svcd but it seems the quelity could be better,is there some quality settings to change within ffmpegX? thks for any tips.
  1. Installation of ffmpegX on os X.6 : error message
    By Gruntosaure in forum ffmpegX general discussion
    Last Post: 22nd Dec 2010, 18:54
  2. ffmpegx Error Message.
    By Bunky in forum Mac
    Last Post: 25th Oct 2009, 08:38
  3. ffmpegX won't install, it gives an error message.
    By kcnightfang in forum ffmpegX general discussion
    Last Post: 8th Aug 2008, 11:50
  4. ffmpegX > what means error message "DIV16_KEY"?
    By infopartner in forum ffmpegX general discussion
    Last Post: 29th Jan 2008, 15:09
  5. Replies: 0
    Last Post: 25th Aug 2007, 16:41
