Does VCD's allow Dolby surround sound because it's my understanding that it is encoded within a stereo track.
I really need a reply to this.
Thread: Dolby surround
Nooooo, you really need to do some searching on this forum under that topic heading to find your detailed answer to a topic that has been run through the mill several times over...in a word, YES
If you have a Dolby ProLogic Reciever or better then the reciever will convert the stereo tracks to Dolby ProLogic surround, but you cannot put DD 5.1 on a VCD.
Realmedia! The Nectar of the Tards!
i do not believe vcd supports dvd surround but i think it supports tv surround sound.
no VCD can have a regular dolby surround..NOT DOLBY DIGITAL SURROUND...regular dolby surround..do some searching too
Dolby surround is nothing but an algorithm that process stereo signal into surround sound, so another stereo input can have dolby surround. It is Dolby Digital that is gives you 5.1 output.
That's right.
Dolby Surround is just a way of putting in two extra (centre and surround) but not discete channels of audio into any stereo signal. You will need a Dolby Surround or Pro Logic decoder to be able to hear the extra channels.
You can have Dolby Surround encoded audio in ANY stereo signal.
That is, you can have Dolby Surround audio on a normal CD, over FM radio, on a LP, MP3, etc.
Regards.
Michael Tam
w: Morsels of Evidence
Splitting AC3 Dolby Digital 2.0 (surround) into seperate WAVs?
By Asaki in forum AudioReplies: 2Last Post: 29th Apr 2011, 14:18 -
Demux a Dolby Surround 2.0 file into separate streams?
By GavSalkeld in forum AudioReplies: 26Last Post: 6th Nov 2010, 17:38 -
ac-3 pro plugin and dolby surround
By ecc in forum AudioReplies: 1Last Post: 24th Dec 2009, 11:14 -
Converting WAV file to Dolby Digital® 5.1 Surround
By roma_turok in forum User guidesReplies: 18Last Post: 16th Nov 2008, 22:32 -
Dolby Digital Surround EX encoder
By grasswhopper in forum AudioReplies: 1Last Post: 17th Aug 2007, 23:49
