I often see that some of you transfer your old VHS videos by using a camcorder. Can anyone give me some idea how this is done? I have just bought a DV JVC Camcorder but I’m not sure how to do this. I have also have Pinnacle DC10 on WinXP pro
Many thanks
Brian
I'm not familar with your particular camcorder, but first off you must ensure that it has analog inputs (composite or s-video). You cannot transfer analog video otherwise!
So if your cam has this there are usually two options.
1. Record straight to DV tape
2. Use passthrough if available
With passthrough, your cam digitizes the footage in real-time and pumps it out the DV port (into your computer). Obviously this route will save you time.
So if you have analog inputs, you then need a firewire card on your PC. This is how you will get your new digital video into the PC.
Software? Try Windows Movie Maker free with Win XP for 'capturing' your new digital video. Excellent for beginners.
Now read the guides to your left for an abundance of information!
Thank you very much for this very helpful information.
Regards
Brian
I have been transferring VHS to HD-then to vcd using a sony dcrtrv340 camcorder. This particular model has the analogue to digital passthrough, which does make things a lot easier. I am not sure if your model JVC camcorder has the passthrough, you would need to check your manual. I know in australia it is only the more upmarket models that had the passthrough. The passthrough option on the sony is accessed through the menu on the camera. I use ULead Videostudio5 which came with my firewire card. This is an older piece of software which takes a little bit of getting used to but it has given good results for me so far (on VCD).
Should I use S-VHS cable for standard VHS transfer?
By Gibson's Squares in forum Newbie / General discussionsReplies: 11Last Post: 16th Feb 2012, 12:50 -
VHS-C transfer: adapter or camcorder?
By moxiecat in forum RestorationReplies: 31Last Post: 15th Jun 2011, 17:18 -
Video transfer from camcorder to PC
By tony_baruti in forum CapturingReplies: 6Last Post: 25th Nov 2009, 11:33 -
transfer from camcorder to computer
By stratman in forum Newbie / General discussionsReplies: 4Last Post: 29th Sep 2008, 10:07 -
16:9 transfer via Panasonice 4:3 camcorder
By wozmac in forum CapturingReplies: 4Last Post: 22nd Apr 2008, 15:27
Statistics
Newest guides
Latest tool updates
New media comments
