VideoHelp.com Forum
  1. hi,
    i had created a photo VCD using NERO 5.5.4 (by clicking and dragging all the JPEG photos in the VCD menu). It works fine, but the silence while viewing the photos doens't look nice. Is there anyway adding some background music?? anyone pls help.
    thanks
  2. I don't think it is possible unless made an mpeg still movie.
  3. use tmpegenc to encode. this is what i did on my bmp.
    on VIDEO, click on your jpeg,
    on AUDIO, click on your background music wherever that may be and on OUTPUT, name your file, configure and hit ENCODE. but this works only on each jpeg. after encoding, burn it using Nero.
    read the walk through in the how to author section to the left i made some good stuff using it its prety simple
  5. I researched this myself and actually made a couple of slideshows with sound---let me tell you--it wasn't easy. It ended up taking about 9-16hrs per disc in encoding time, prep time, etc. I seem to remember that I used Virtual Dub to convert it to an avi before I converted it back to mpeg with TMPGenc, but I forgot all of that once I found my simple solution:
    WinOnCD 3.8 Power Edition.
    When I got that program, what once took me 10hrs took me only 3 minutes to make. It was soooooo easy.
    If you can get this program, thats what I would recommend.
    Good Luck
  1. Replies: 2
    Last Post: 11th Aug 2011, 15:32
  2. Replies: 2
    Last Post: 21st Jan 2011, 06:25
  3. How to add background music?
    By coody in forum Audio
    Last Post: 25th Sep 2008, 16:04
  4. Replies: 3
    Last Post: 10th Apr 2008, 12:56
  5. How to lower background music
    By auroragb in forum Audio
    Last Post: 24th Jul 2007, 20:54
