1st: plz excuse my english
I have a serious problem when capturing from VHS (PAL). The amount of dropped frames seems to depend on the TV station I've recorded the tape from. When I capture directly from the same station (NOT from a VHS copy of the station) it works fine. Half of the dropped frames are always exactly at the same position, the other half varies. These "fixed dropped frames" are clearly visible on the computer screen while capturing but on TV the tapes look fine, absolutely no dropouts are visible there.
Usually I can capture a long time without loosing more than a frame every two minutes. On the problem stations I loose around 30 frames per minute. So I think it has nothing to do with my hardware. I don't think it has something to do with audio, too. The frames are also dropped if I don't capture any audio at all.
Results 1 to 1 of 1
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum CapturingReplies: 12Last Post: 17th Aug 2011, 22:33 -
Dropped Frames
By SudsMalone in forum CapturingReplies: 4Last Post: 21st Feb 2011, 05:31 -
You Get dropped frames? That's for you
By themaster1 in forum CapturingReplies: 2Last Post: 6th Dec 2009, 22:21 -
Dropped Frames
By dano404 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 8th Mar 2008, 13:57 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum CapturingReplies: 0Last Post: 23rd Aug 2007, 20:59
