VideoHelp.com Forum
  1. I have a vid which is in a bin/cue , it is a svcd. The problem i have is, my dvd player doesnt play svcds, but they work when i do the vcd header trick on the svcds.
    I need to be able to create/extract the svcd/ mpeg-2 file from the bin/cue files. I have had a go with vcdgear but the resulting mpeg-2 file wont play or load in TMPGEnc??
    Can anyone help or point in the right direction!! thanks
  2. Member Laddydaddy's Avatar
    It's possible your file is corrupted. Can it play in your software dvd player (i.e. windows media, power dvd, etc.)? Load it into avicodec and see what info you get on the file. It sounds like your dealing with a downloaded video which may not have an audio or video file associated with it.
    download a free product called DAEMON Tools. You can mount bin/cue in a virutal CDROM drive. Useful for testing files before burning (CD or DVD doesn't matter). You can then mount the file, and open it in whatever program you need. There is a difference between copying the MPG file and ripping the MPG file.
    Alternately, ISOBUSTER can do the same thing, then you can copy the file out or rip it out.
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  4. still ahving probs. when i burn the bin/cue file to svcd it plays on software but if i load it into anythying like gspot the prog stops running???
  5. Member Laddydaddy's Avatar
    Try avicodec which supports mpg files.
  6. ok i used the DAEMON Tools to mount bin/cue in a virutal CDROM drive, and then loaded the mpeg into avicodec and it loads ok: it says
    File : 797 Mb (1.3 Gb), duration 0:54:00, type MPG, 1 audio stream(s), quality 88 %
    Video : 973 Mb, 2520 Kbps, 29.970 fps, res. 480*480 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
    Audio : 86 Mb, 224 Kbps, 44100 Hz, 2 chan., 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
    Does this help???
  7. I'm a Poll Super Moderator johns0's Avatar
    use vcdeasy to rip the mpg,it removes the riff header and lets u use it properly
  1. cue and bin files
    By natty in forum Newbie / General discussions
    Last Post: 21st Jun 2011, 15:25
  2. extracting the bin/cue from .oo1,.002 etc files
    By belwas in forum Newbie / General discussions
    Last Post: 7th Jan 2010, 00:59
  3. Having trouble with .bin/.cue files
    By UncleBose in forum Software Playing
    Last Post: 12th Jan 2008, 06:06
  4. Replies: 2
    Last Post: 24th Jul 2007, 09:11
  5. What files/settings do I need for bin/cue
    By Choppa in forum Authoring (VCD/SVCD)
    Last Post: 23rd Jun 2007, 21:29
