Hi just started out on this game, this site is real cool, and looks like a lot of you guys no heaps about the subject.
The problem I have is i uses snartripper, DVD2AVI and then Tmpgenc (all latest versions) to write output using sevys SeVCD template, the audio side on the Video CD is low in output, it is not distorted though.
Any ideas what im doing wrong?
Thread: Low Audio Output
I think you should check your settings in DVD2AVI.
All Audio settings:
Under 44->44.1 KHz see that "ultra high" is checked
See that "Normalization" is checked and when the Volume gauge appears, move it to a higher level.
This should help you
part of the reason for this is that DVD audio has a higher dynamic range than CD audio, so that when you record you want to make sure the loudest DVD sound doesn't exceed the range of 16-bit CD audio. since the loudest sounds on a DVD are usually much greater than the rest of the soundtrack, you must make normal sounds comparatively quieter (and very low sounds almost disappear) in order to avoid distortion.
I know this might sound a bit stupid
but make sure your volume controls within windows
are set to max ie for yoyr soundcard etc
just my twopenneth
cya
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Thanx for the tip it worked, really appreciated
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum CapturingReplies: 12Last Post: 14th Dec 2010, 16:59 -
Low Sound Output After Adding .ssa to .avi
By edlimym in forum SubtitleReplies: 4Last Post: 12th May 2010, 07:02 -
HDTV Audio output is too low. Help
By daustemd1551 in forum AudioReplies: 1Last Post: 1st Nov 2009, 20:08 -
Auto-GK file output, low quality despite large size
By Fallout1 in forum Newbie / General discussionsReplies: 10Last Post: 5th Oct 2009, 18:27 -
Low Audio Output
By house141 in forum MacReplies: 6Last Post: 17th Jan 2008, 23:16
