I'm fairly adept at capturing from my TV card using VirtualDub and WinDVR. Now I have a question regarding capture from a Sony miniDV camcorder. Would it be better to hook the camcorder into the S-Video socket of the TV card and use VirtualDub or WinDVR, or to use the Sony-provided ImageMixer program through the USB port?
Results 1 to 12 of 12
Thread: Sony camcorder capture questions
The BEST answer is buy a $25 firewire card and capture with that.
Barring that, I suspect the TV card will do better. Unless your DV outputs already encoded MPEG data, you'll be limited to quarter screen captures on USB, and probably STILL drop frames.
get firewire. USB = cheapy graphic, squares everywhere, graphic suck like h.... usb 4 pix only, i used to usb and thought my cam suck, found out i have to get firewwire.
Yep, get a firewire card that already comes with the cable. The cable by itself could cost $15.
15 bucks = cheap, i got mine from FRY's ELECTRONIC for 25 bucks (cable included).
Wow - guess I need firewire.
Definitely
Just because you aren't paranoid, doesn't mean they aren't out to get you!
I got mine at Fry's for $39. It came with; 4 port PCI card, 6ft I-link cable, and Ulead vieo Studio 6. Well worth it. No driver software needed, Win XP pro recognized and installed it.
Same here, auto detect...but i got Video Studio 4
Wasting your MiniDV money if you don't use firewire
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
I agree that the firewire is the way to go. I have a Sony MiniDV cam, and use Pinnacle software to make movies to SVCD. Very, Very easy.
Perhaps you can tell me how to record shows with WinDVR, and then burn them to VCD, so that I can play them on my DVD player! Thanks!
tom_ragatz@rac.ray.com
tragatz@cox.net
check E-bay. After my son ran over my cable with his chair, I found the cable at Best Buy for about 20 bucks. I then went to E-Bay, and found a new cable for $4. Worth the wait!
Tom
Can't find my camcorder to capture video in Sony Movie Studio 9
By Greg / MO in forum CapturingReplies: 12Last Post: 8th Aug 2010, 00:39 -
Capture from Sony Camcorder/Firewire connection stopping in 4-12 seconds
By tepeco in forum CapturingReplies: 4Last Post: 16th Apr 2009, 11:24 -
Capture analog video from sony camcorder
By gthoman in forum CapturingReplies: 14Last Post: 14th Apr 2009, 14:32 -
Questions for Improving Sony DCR-TRV22 Video Capture Support
By fredberry in forum CapturingReplies: 3Last Post: 2nd Nov 2008, 14:59 -
not impressed with capture from my sony mini dv camcorder
By tunde121oke in forum Camcorders (DV/HDV/AVCHD)Replies: 13Last Post: 2nd Jan 2008, 11:43
