VideoHelp.com Forum
  1. The sound works on my PS2, so I know the disk works, but when I try on my Toshiba SD200e / Sony STR-DB930 system, I get no sound. The amp doesn't seem to register a digital stream from the DVD player, but I'm not entirely sure where the problem lies - any ideas?
    These are home made DVD-R's by the way...I'm going to try AC3 sound to see if that makes a difference next, but authoring software support for AC3 doesn't look great - ULEAD doesn't like it, and Spruceup seems to be locking up when I try to import a stream with AC3
    Remember that US DVD players are not required to play mp2 sound. PCM or AC3 (and DTS, but I believe it only has to pass it through to a DTS receiver) are supported. If you player can't play SVCD's , then it most likely won't play MP2 audio.
    Does it play mp3's?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
  3. thanks for the info
    my dvd player does not play svcd's, you are correct I guess this is where the problem lies then. It doesn't play mp3's either
    I've just been playing around with lfoedit, ulead and spruceup, and none of them seem to like authoring a video file with AC3 format sound I don't suppose you have any experience of this and/or possible solutions?
  1. My Sony CD/DVD player (NS55P) would almost only play sony discs.
    By valdes001 in forum DVD & Blu-ray Players
    Last Post: 30th Jan 2011, 10:03
  2. Toshiba sd 7200 no sound after hack
    By Godiva in forum DVD & Blu-ray Players
    Last Post: 24th Jan 2010, 16:11
  3. Help with a sound issue on a Toshiba SD-6100
    By hhcup in forum DVD & Blu-ray Players
    Last Post: 9th Apr 2008, 09:06
  4. Sony selling their Blu-Ray factory to Toshiba
    By G)-(OST in forum Latest Video News
    Last Post: 23rd Feb 2008, 07:43
  5. Does Toshiba HD-A2 play SVCD's?
    By desertfox in forum DVD & Blu-ray Players
    Last Post: 20th Aug 2007, 09:40
