I wonder if i have a pentium and a Pentium4-HT processor, which one will produce better video quality that both using the same parameters in encoding. Or it is just the encoding time different..?I am trying to produce better quality video and think if the processor can help a little..!
The processor will only make it go faster.
There can be audio/video synch issues when a processor is overworked.
When I tried to do something else while converting a DVD I noticed some synch errors. When I leave it alone the output is ok. I have a P4 1.6 with 512 DDR 333 (2700) ram. I wonder if I had a P4 2.8 if this would be an issue. It may be that the problem is a bottleneck someplace else such as the HD but it's hard to know for sure.
When capturing your own video it can make a lot of difference.
As to video quality during processing... Some apps are specifically designed with features or plugins only available with certain processors such as SSE SSE2 bicubic resizing. Whether or not that counts as a quality enhancement or is purely a speed improvement using a more advanced instruction set I do not know but it's the only thing that comes to mind.
Other than that I have to agree with DivXExpert.There's not much to do but then I can't do much anyway.
Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p file
By SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 07:57 -
By SgtPepper23 in forum AudioReplies: 1Last Post: 5th Dec 2009, 21:33 -
PSP V5.00 Video Specs for FFMPEGX 0.0.9y - Higher Quality?
By boomhaueruk in forum ffmpegX general discussionReplies: 0Last Post: 27th Apr 2009, 11:38 -
YouTube offering higher quality video / Stage6 ends services!
By bayme in forum Video StreamingReplies: 610Last Post: 25th Dec 2008, 01:11 -
which scenario gives a higher quality video?
By graysky in forum DVD RippingReplies: 19Last Post: 3rd Sep 2007, 10:40
Statistics
Newest guides
Latest tool updates
New media comments
