I have a Pioneer A04/104 DVD Burner.
I am looking for the best quality DVD-R media, price does not matter. I'm looking for the overall most stable and compatible blank disks possible.
Results 1 to 16 of 16
I've burned over 200 TDK 2x (Singles, 10-packs, or 15 pack spindles) and the only 1 or 2 costers were self induced.
Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
I like Samsung BeAll, but I don't think they burn @ 2X in the Pioneer burner. You didn't specify if burn speed is a necessity.
Burnspeed does not matter either. 8)
Apple = Reliable, fast 2x, reasonable cost.
I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
1.TDK
2. Real Verbatim's not the new CMC's
3. Taiyo Yuden
but if i had to pick my fav..it would be tdk.
hey vinnysem....are you burning beall's at 2x on your sony ax.....and if so what firmware..i just bought a 50 pack from gayline... also are you just writing on top of them?..is there any bleed through?
What everyone else said
My picks
Mitsui
Verbatium (made by Mitsubishi Chemical Corp)
Apple (made by Pioneer Video Corp)
Apple disks are not really apple disk really and if you buy them you are over paying -- but they are good disks ..
but these are all the same disks - notice the big price spread depending whose name on it ..
http://www.dvdrhelp.com/dvdmedia.php...archdvdplayer=
If it's going to be once only (-R/+R) then I use Verbatim. If it's a disk I'm going to be re-using over and over (-RW/+RW) then security is not that much of an issue so I use Imation +RW (because the burn speed is 2.4x as opposed to 2x for -RW).
Regards,
Rob
Yes the BeAll's burn @ 2X in my DRU-500UL. I have the 2.0e firmware, but I believe it did since 1.0f. I've always just written on the tops of disks with a Sharpie, but I get the branded ones. I don't like the silver top disks for asthetic reasons. shop4tech has spindle packs of the branded media.Originally Posted by peeps
I recently purchased a spindle of Optodisk media, 80 cents a piece for 100 from rima.com. They burned @ 2X and had good compatibility with the set top players I tested.
LOL, OPTODISC? HAHAHA, get a better job and u can afford better discs.
Well, if price is no object then why not just buy authentic Pioneer brand media?
What is wrong with those discs. I have burnt over 200 of those things now and lost one from its own faults and 2 that were my fault. Why the hell would someone want to spend more when those discs work for them. Your right i probably need a better job to. One that pays more, one that doesnt make me leave my family for a year to move to south korea. I hate people like you. so why dont you take your better discs and cram them sideways up your ass and stop ragging on people for not spending more when less works for them.Originally Posted by jaxxboss
Shochan
I've burnt several Pioneer DVD-Rs, and I've found the quality to be better that the Optodiscs,BeAlls, and Princos. But it's not significantly better, considering the price. The Pioneers load faster that Optodisc, and princos. Riteks are probably the best quality vs price choice, in my opinion. Although the Emtec discs I've burned had better than average (the three above)quality. And they're the same price as Optodiscs.
Price of blank DVD media - Why gone up in the economy?
By contract73 in forum MediaReplies: 18Last Post: 6th Jan 2010, 02:03 -
PlayOn Media Server Half price, $19.99
By handyguy in forum Video StreamingReplies: 1Last Post: 28th Jun 2009, 12:03 -
DVD dual layer media ~ thickness/price
By Micker_C in forum Newbie / General discussionsReplies: 10Last Post: 5th Nov 2008, 23:23 -
Best all around Media at the lowest price & how to receive best results
By uncleB in forum MediaReplies: 5Last Post: 13th Dec 2007, 13:02 -
Image PPI -> DVD slideshow...does it matter?
By Grunberg in forum Authoring (DVD)Replies: 1Last Post: 12th Nov 2007, 17:06
