anybody know any decent free tools or software that will let you clean up old videos. i want to capture some of my old vhs stuff and convert it to vcd or divx, but i'd like to be able to fix some picture problems.
thanks
Thread: cleaning up old videos?
give magix video deluxe a try.It has some effects. I tried the demo and found lots of tools to enhance VHS-Video (or so they claim). I'm not really using it, because for editing I'm used to ULEAD mediastudio.
Use Vdub's filters
Any suggestions for some basic filters/settings for old vhs would be greatly appreciated!
thanx,kristin
I'm using the contrast/brightness and the DNR (dynamic noice reduction) filters within virtualdub. But beware, if are using DV-Format as input, you have to switch the dvsd codec everytime if you are going from Mediastudio to V...Dub and back again.I'm using regedit to do this. (rename the the key vidc.dvsd to vidc.dvsx and vice versa.
Check out www.geocities.com/lukesvideo/
Read through the "low res processing" and "high-res processing" sections.
This was the first guide I used when I first started using noise reduction filters and it is a good place to start.
Thanks...
Thanks for the help...know that these are not going to end up as beauties...but have to do something before they're dust!
Kristin
Cleaning up compression artifacts in YouTube videos.
By majin_buu in forum RestorationReplies: 15Last Post: 13th Sep 2011, 08:57 -
head cleaning
By kb 801f in forum Newbie / General discussionsReplies: 4Last Post: 28th Nov 2010, 12:09 -
cleaning dvd's
By the_shyguy in forum MediaReplies: 25Last Post: 7th Dec 2009, 04:39 -
I need some help cleaning up Audio.
By efb91 in forum AudioReplies: 1Last Post: 22nd Sep 2007, 13:28
