1 Hi guys i was just wondering how to use plug ins in his proggy. I have
never used plugins as such and was wondering how i can use a plugin
on a dv footage i have.
2 I Also want to know if i cap stuff from studio8, how do i edit out stuff i dont want in virtualdub. Well actually i know how to do that but wanna know if i use direct stream copy and save as avi, will it keep the original dv quality?
thanks
Thread: Adobe after effects
there are 100's of plug-ins for AE ... most come with instructions ... don't know really what you are asking here ..
WHen you say plug-ins do you mean like additional transitions and effects? If so then your new ones will be added to the transition and effects menus.
Adobe After Effects, how do you view all layers at once??
By Devilsadvocate in forum EditingReplies: 5Last Post: 2nd Mar 2012, 11:58 -
Whats the alternative to Adobe After Effects ?
By AjnabiZ in forum EditingReplies: 15Last Post: 19th Oct 2011, 17:33 -
Adobe After Effects Questions
By HoosierGuy in forum EditingReplies: 25Last Post: 2nd May 2011, 21:12 -
Adobe After Effects issue
By Coroni in forum EditingReplies: 3Last Post: 22nd Oct 2010, 20:56 -
1001 Adobe After Effects Tutorials
By Dennis_H in forum EditingReplies: 2Last Post: 1st May 2009, 21:21
Statistics
Newest guides
Latest tool updates
New media comments
