VideoHelp.com Forum
  1. My question isn't quite as basic as it seems. I have been upping the bitrate when I make movies (to 2450, and the audio to 224-338) and I was wondering whether files that are not firsthand can be improved by converting the avi to a higher quality MPEG. I only ask because I have been doing tests with some movies and the difference seems to be nil. For example, bitrate from 1150-->2450, with motion search precision on high quality, and noise reduction on (though I don't think I need it), and still there doesn't seem to be much difference. I have been viewing the difference on my computer rather than my TV (in the shop) but shouldn't I be able to tell anyway? The sources I have been using are all movies from Kazaa. Thanks for any comments.
  2. Ok, you can ignore my comment. I checked, and though the preview for VCD's on tmpgenc does not work, I can see a big difference when I decrease the bitrate, so it should work the other way, though it seems to be a lot less dramatic.
  1. Improve m2ts quality?
    By FatalX in forum Video Conversion
    Last Post: 27th Nov 2009, 14:06
  2. What can I do to improve my quality?
    By Captain Satellite in forum Restoration
    Last Post: 27th May 2009, 11:06
  3. Replies: 4
    Last Post: 29th Dec 2008, 13:38
  4. avi to youtube - awful quality, how do I improve it?
    By Spike__ in forum Video Conversion
    Last Post: 23rd Feb 2008, 13:50
  5. Can DVD -> AVI -> DVD improve quality?
    By JoeBolden in forum Restoration
    Last Post: 26th Jul 2007, 05:03
