okay, so i recorded "Lucky" on TV, but i recorded two 1/2 hour long episodes on back to back, so i ended up with a 3.5 gigabyte one hour .mpeg file. then i ran it through mpgmediator to convert it into a readable (in v-dub's eyes) smaller .avi file, so then i open the 625 megabyte .avi file in virtual dub in order to splice the commercials out and separate the two episodes.
for the first episode, i simply went to the end of the first episode, started a hash, skipped to the very end of hte file, and closed the hash and removed the video. but then i noticed that the video cuts out probably 3/4ths through the file.
when i went to do the second, i started a hash at the beginning of the file, and moved to the end of hte first ep and closed the hash and removed it. i then started going through the file removing ocmmericals, when i noticed that virtual dub did not read the file beyond a point. this part of the video exists because i checked it in WMP. it is a 52 minute .avi file, but virtual dub only goes about 40 minutes into it. even after removing hte first 28 minutes, there were only the remaining 12 minutes of the secand half of the file.
has anyone experienced this problem before? is there some sort of setting that will allow it to import the entire video file? is this a bug?
i'm going to try to delete the first portion of hte video, save as .avi, and then re open the smaller .avi into vdub to see if that remedies the problem.
bump
seriously does anyone know what's wrong with this? i tried to save as a diff avi in v-dub, but uncompressed it was 7 gigs which is too large for my fat32 partition.
what the hell does anyone know?
VirtualDub File [path] does not have a video stream error
By fershad in forum Video ConversionReplies: 4Last Post: 25th Jan 2012, 06:11 -
VirtualDub D2V file error
By Dr.Who in forum Video StreamingReplies: 5Last Post: 17th Dec 2010, 14:23 -
Editing video in virtualdub taking so long!
By admirer in forum Newbie / General discussionsReplies: 14Last Post: 8th Apr 2010, 13:43 -
VirtualDub "NewMovieFromFile" error w/mp4 file
By smk42 in forum EditingReplies: 3Last Post: 31st Dec 2009, 00:37 -
Error while drugging MPEG 2 file to virtualdub
By eliqush in forum EditingReplies: 8Last Post: 4th Nov 2009, 08:53
Statistics
Newest guides
Latest tool updates
New media comments
