Any ideas how to accomplish this? The idea is basically the same as with the SW EP1 and EP2 dvd's, to have many different firstplays/menus that the player/softwaredvd can choose from.
I don't have Maestro or the manual in front of me right now, but you can do it with the Commands. I remember that one of the options is to generate a random number in a certain range.
Then you just have to create a command structure that first runs a random number generation, and then looks at that number and calls a specific movie or menu based on the value of GP0.
I know that doesn't answer it fully, but it is the best I can do without looking at it. Go in to the commands and explore, or someone else might post.
Good luck!
Yes, it's possible in Maestro. I've done it before.
You can also do a weighted semi-random play, what I like to call the "Lucky Contestant". Same show or range of shows play everytime except once in a blue moon "special" footage will show up.
I'm not at work so I can't show an example right now, but I'll try tomorrow.
Reel to Reel audio tapes player recommendation
By neuz in forum Newbie / General discussionsReplies: 23Last Post: 11th Sep 2011, 06:26 -
Machines to play Reel to Reel movies ?
By 1234567 in forum CapturingReplies: 13Last Post: 26th Mar 2011, 05:37 -
5 Inch Reel to Reel Tape Question
By daave in forum AudioReplies: 12Last Post: 18th Mar 2011, 00:13 -
recording old reel to reel audio
By devdev in forum AudioReplies: 4Last Post: 24th Jan 2010, 14:54 -
UOP for FirstPlay
By grzegorz in forum Authoring (DVD)Replies: 2Last Post: 9th Apr 2008, 07:58
Statistics
Newest guides
Latest tool updates
New media comments
