VideoHelp.com Forum
  1. Which settings do you use and for what?
    Normal, soft, fine, cinema or do you manually adjust?
    How about mpeg-dnr? On or off, or do you define your own settings?
    I appreciate your input.
    scottymac
  2. Anyone have any suggestions about these items?
  3. To answer my own question, I have found that the standard Normal and DNR-NR on looks great.
  4. wanting to bring this post back up for viewing.....
    I am hoping the panny guys and galls might be able to offer some advice/input into preferred settings.
    For home movie vch to dvd conversions, which is the better settings (XP or SP)? Obviously it would be XP, however, is the downgrade from 1 hour to 2 hour that noticeable? that and are the default settings the way to go, or has someone found the "magix" settings for SP mode?
  5. Originally Posted by macleod
    I find a noticeable difference between XP and SP, but I'm as ultra-super-critical as they come. SP is really quite good, but you can find a little bit of "pixellation" or whatever when things move, and it's just all a tiny touch less "sharp" overall compared to XP. XP clears up that "motion" stuff just fine, and is very nice and sharp.
    I have stuff where picture quality is my Number One priority, even if I'm just dubbing from VHS, and I use XP on that. I'm on a mission to save stuff on no less than about 1,500 VHS tapes, and dang if I'm gonna save some of that stuff at any less than the best quality I can get. I have other stuff where picture quality isn't all that critical, and then I economize and record that at SP.
    Hope that helps!
    thoots
  1. What settings will give me the best picture when rendered at 720p?
    By ItsJustAGuy in forum Newbie / General discussions
    Last Post: 10th Feb 2011, 08:21
  2. CAnopus advc-55 to use with jvc S-VHS with TBC/DNR
    By MrTemplar in forum Capturing
    Last Post: 11th Dec 2010, 16:04
  3. TBC/DNR on my JVC HR-S7600U
    By ministry88 in forum Capturing
    Last Post: 26th Mar 2009, 04:42
  4. DVP5990 Best Picture/Audio Settings?
    By avkhatri in forum DVD & Blu-ray Players
    Last Post: 18th Feb 2009, 13:47
  5. The JVC vcr TBC/DNR makes the picture worse. Why?
    By KeepItSimple in forum DVD & Blu-ray Recorders
    Last Post: 8th Jan 2008, 01:12
