Can someone explain to me how to extract the audio track from an AVI file that was captured via a DV card? DV seems to rule out VirtualDub. I'm trying to ultimately produce an AC3 audio track to use with an MPEG video-only track created via TMPGEnc. Only solution I've figured so far is first extracting to a WAV file using GoldWave, and then converting it to AC3 using BeSweet. Problem is: (a) this seems a fantastically roundabout way of doing it and (b) I can't figure out how to work BeSweet anyway, even with the GUI.
Any suggestions?
Try going to www.doom9.org. Click on guides and then clink on format conversion and then click on CCE. Go down to step 2 titled audio processing and then read this section and download any files that are the guide tells you to. Follow the instructions
Good luck,
VCThis is so much fun!
HELP for extract DTS or AC3 audio from MKV
By Riversound in forum AudioReplies: 5Last Post: 29th Jan 2010, 10:56 -
extract entire ac3/dts audio track from a DVD
By shiet in forum AudioReplies: 1Last Post: 24th Feb 2008, 02:26 -
Tracking down old AVI container create/extract software
By lostinlodos in forum Video ConversionReplies: 5Last Post: 16th Dec 2007, 03:26 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 04:56 -
Extract sound from AVI video and convert to AC3
By blizzery in forum AudioReplies: 2Last Post: 25th Jul 2007, 14:06
Statistics
Newest guides
Latest tool updates
New media comments
